Flat cable broken
Nixo
Hi everyone, this morning I open up my portable (Cortail II) because the led indicator wasn’t show any lights, in the meantime I was looking for the cable that is connected to the main board, and it was pretty bent, I put everything back in place and the laptop won’t turn on anymore, the only thing that coming on is the keyboards backlight in the color that I put when the pc was working, I tried to power on via the battery and the power cable but nothing only the keyboard go on, the pc turn on only with the power cable in.
I start to disconnecting everything from the main board but nothing, the pc won’t to turn on, I hope that the problem is that flat cable, I tried to power on the pc always with the led indicator/power switch.
If someone know why the pc doesn’t turn on but the lights turn on please reply to this message. I want to fix that problem with my portable.
Specs of my pc:
DisplayRecoil Series: Widescreen 60 Hz 72 % NTSC LED full HD 15,6" (1920 x 1080)
(CPU)Intel® Core™ i7 8750H 6 core (2,2 GHz, 4,1 GHz Turbo)
(RAM)DDR4 SODIMM Corsair 2400 MHz 16 GB (1 of 16 GB)
Graphics cardNVIDIA® GeForce® GTX 1060 – RAM video 6,0 GB GDDR5 – DirectX® 12.1
1o drive SSD M.2SSD PCIe WD Black™ M.2 NVMe 500 GB (fino a 3400 MB/s R | 2500 MB/s W)
AudioAudio + SoundBlaster™ Cinema
Bluetooth e wirelessLAN GIGABIT e WIRELESS INTEL® AC-9260 M.2 (1.73 Gbps, 802.11AC) + BT 5.0
USB/Thunderbolt1 PORT USB 3.1 (tipo C) + 2 PORTs USB 3.0 + 1 PORTUSB 2.0
Specs of my pc:
Hello, these forums are Italian Language only please, if you need the English forums please go to https://www.pcspecialist.co.uk/forums/
